Overheating at 30mph
Lou C
Ah saw that it was rebuilt; so the shop must have boiled out the block & heads
QBhoy
I think it’s worth checking that impeller again. Doesn’t take much to ruin them quickly. Especially if you had an attempt at running her on the muffs and hose before putting her in the water. Can be a 50/50 if these will pull water up from some muffs.
Galvez83
The new impeller has been ordered since its cheap insurance i rather just knock it out. Then while there, review all hoses and hose clamps. Who knows, i might get lucky with it and ends up beign a loose hose.
nah.....
the typical locations for air ingress on a generic volvo installation are the casting on the drive, the seals on the raw water pump, the cover on the raw water pump, the swivel seals on the drive.
a clear hose between the raw water pump and the rest of the down stream engine is vital for troubleshooting. if you see bubbles, you have an air leak.
to get more specific on other possible ideas of overheat, we need to know which cooling system etc. is on your boat.
have you back-flushed the power steering cooler for debris as this cooler is usually plumbed between the pickup and the raw water pump
overheating is simply a lack of raw water flow and going thru the system to check what may be causing low flow.
Galvez83
nah.....
nah.....
Engine is raw water cooled. I backflushed from water pump incoming water hose. I opened the cleanout on the outdrive and nothing came out prior to this event. Engine 5.7 dp-sm
Horigan
Have you checked the water inlet on the drive, item #9 in post #7? If that's cracked that can lead to your symptoms.
Galvez83
Last i checked upon install it was in good condition. I ordered one just to have peace of mind.
Donald0039
I am read some people have by mistake reversed the raw water hoses and that causes issues. My two hoses are slightly different diameter so they cannot be reversed.
Pull thermostat and double check in pan of hot water. Hang by a string.
IR thermometer will be very beneficial for diagnosis. Once you get this straightened out take temps of manifold and riser and write in journal for future use.
Some rig up some clear hose in line with the hose from outdrive to raw water pump to see if it's full of water or has air pockets.
