Overheating at an idle. Mecruiser 260
CAPTKEV85
I have a 1985 sea ray with 260 mercruiser. At idle it overheats in 3 mins once you go over 1000 rpm's it cools down. Last year I put new thermostat 140 and it still had problem. Then I put sea water pump in drive. Still same problem. Boat has new risers and manifolds too. Any ideas? Thanks
Re: Overheating at an idle. Mecruiser 260
Ayuh,... Water's gotta get in, 'n back out...
Have you tested any of the Flows, anywhere,..??
Pull the in-coming line off the T-stat housing, Any flow there,..??
CAPTKEV85
I'll give that a try tomorrow.
