Overheating DT200
Kurtzhall
I have 1996 Dt 200 that is sounding overheat alarm at high rpms. It runs fine at or below 3500. When it overheats i have felt top of the motor one head is warm the other can't touch(too hot). Getting flow threw pee hole but looks week at high rpms. I also get a large amount of discharge of water out of the upper exhaust port(don't know if thats normal or not). I have replaced the water pump checked the thermostats(opening fine in hot water) and cleaned the oil flow sensor. Can anyone help not sure where to look next.
99yam40
Re: Overheating DT200
At what temp are the thermostats opening and closing, and how far are they opening. There are specs in the manual for these things,
Did you replace just the impeller of the whole kit, how did the water pump housing look?
You may need to look for places the pump could suck air from. I have read corroded pieces below and around the pump will cause this problem
Kurtzhall
not sure of the temp there opening.I plan to replace any way. The houseing around the impeller looked good was'nt wore down. i will look again. I have been give a few things to look at like i may be trimming to high but never had issue before and to look at the base gasket but of course that means pulling the power head any sugggestions thanks
