Overheating issue
redright9
I have a 1996 SeaRay, it has a 5.7L mercruiser with a mercruiser outdrive. I was very stupid and left my boat in a marina a while ago and never took it out to clean it. Since, when running higher speeds and when running in my driveway, the temp goes up and when at higher speeds gets almost to full gauge. When running slow, no problems... Any suggestions? Also, were can I find a service manual for my boat so I can perform maint. on it?
67deville
Re: Overheating issue
Not sure about the overheating issue,but I just bought a Seloc Mercruiser manual for my 120 on this site.They are great,they cover just about everything.
Alpheus
Sounds like you may have some growth in your water passages. I would not run it anymore until you get this fixed.
MPII
I found downloadable original mercruiser factory manuals for my merc 4.3 on 4shared.com. There are links on this site.
redright9
I couldn't find what I was looking for on that site.. Thanks though.. I am looking into a service manual to see about digging into it further.
MPII
That's wierd, I found both manuals, over 400 pages each on that site. I got the links from this site. If you want to private message me with your address I don't have a problem sending you a CD. They are too big to email, over 100 MB.
dubs283
number one cause of higher rpm overheats on alphas is the lower gasket seal on the water pump is failing, allowing exhaust gases to be sucked into the cooling water
time for a new impeller/gasket kit install
also, as stated, check for marine growth in pick up area
fjm308
i had the same problom with my mercruiser 5.0 it was one of my exhaust flaps on the exhaust elbow assembly was sucked in the one side of the manifold.
