Lewis1111
- Joined
- Jun 1, 2013
- 62
Hey everyone really need some help with this one. I've poured through all the other forums and can't seem to figure this one out. The engine is 2000 M/C 3.0L Ser#L639645.
I am having a overheat issue....The temp gauge will slowly climb to 200 and I can confirm that when checking with temp gun at the t-stat housing. Thinking it was the impeller and since it has not ever been done I decided to put a new kit in. New impeller and hsng as well as all new gaskets. Go to run up again and it displays the exact same as before. It is pumping water well out the t-plate and has good water flow to the t-stat hsng.
Last year the c-pump was leaking so that was replaced as well as the t-stat last year. I even tried another t-stat this past week and still had the same issue. I removed the exhaust riser to check the flapper and that looks good as well I did a compression test and checked spark plugs for water and no signs. Comp was 150 psi across the board. No water in the oil either.
If anyone has any ideas of where to look next that would be greatly appreciated!!
