bass-kitcase
Thread starter- Joined
- Dec 12, 2009
- 3
I just replaced the water pump impeller on a 1974 85hp Evenrude using a complete kit. I've had this motor for over 30 years and have never had an over heating problem. There wasn't much left of the old impeller but the housing looked ok. I cleaned eveything up and installed all new seals and impeller then reinstalled the gearcase to the motor.
When I took it for a test drive I ran it at a low RPM for several minutes. When I kiked up the R's the overheating horn began to sound. I backed off the throttle and within a few seconds the horn stopped. I tried it again and the same thing happened. It cools ok at low but not at high RPM's. Can you tell me what the problem is?
