overheating
bullstedman
I have just a small amount of water coming out just above my exhaust but dont even know whereto look for my pee hole, i think it is plugged up my pump looks good on erlier inspection. It isa 1973 evenrude 18 horse 18304a. please help thanks in advance.
lindy46
Re: overheating
Water should spray and dribble out the exhaust relief port (that large hole on the back of the leg). That motor doesn't have a pee hole like newer motors. There should be a good healthy spray, but no stream.
bullstedman
Re: overheating
Thank you so much A RELAXING BOAT RIDE MY ***. i pulled off the bottem end and found that i am pretty sure i didnt have the tube that puts water up into the engine,is there a thermostat and do they go bad?
lindy46
Re: overheating
Should be a water tube coming down the leg and attaching to the water pump housing. That motor has a thermostat, and yes, they do go bad.
boobie
Re: overheating
My question would be if the water tube is not there where did it go?
bullstedman
Re: overheating
I missallined the copper tube so i should be ok now . I think i pussed it aside during asembly to where it was to the side. And where would the thermostat be located at? Have a happy new year. I will try it again tomarrow thanks again folks.
boobie
Re: overheating
The thermo is located under a plate on top of the cyl head. Takes 3 bolts to remove plate and get at it. Go to Shop.Evinrude.com and look up your mtr and you will see a good diagram of it.
5150abf
Re: overheating
So you are saying there is no water tube at all in the engine?
Was it there when you looked at the pump the first time?
Don't run this engine till you get this figured out, it doesn't take much to overheat them and cause alot of damage.
bullstedman
Re: overheating
There is a tube in the in the bottom that goes from the top of the water pump to the engine. And now it is hooked up.
Re: overheating
I have been gifted a lonestar with a Evinrude 1965 33hp. I replaced fuel lines and started it in a barrel of water. I only ran for about 30 seconds watching for signs of water pump working but don't know exactly where to look for water coming out at idle and prop in netural. At the back of the gear case group there was 3 ports. This motor has not been in the water since 97. I have a parts manuel.
Bob_VT
Re: overheating
Welcome to iboats!
Just an opinion..... I would replace the impellar just based on the age........ and the lower unit oil too. Those 33's are great motors.
lindy46
Re: overheating
See my initial response, #2 above.
jasper60103
Re: overheating
Those old motors pump a whole lot of water when the water pump is working properly, even when in neutral. Here's a video of my old 28 ideling.
http://www.youtube.com/watch?v=RXx1MFvOz88
