Bluefish221
- Joined
- Oct 2, 2017
- 5
Hi All,
Looking for some more help from you guys! Motor is 2001 OX66 250HP.
After not using the boat for 10 days, something felt a little off on my 8 mile run out. She got out of the hole and went on plane fine, although at 40-41RPM I was only getting 27MPH, whereas that consistently gets me 28-29MPH in same sea conditions. Not that far off, but far enough where I could tell after having this motor for a while that something was off.
On the 8 mile run back, I decided to slowly increase her to WOT (for me 52RPM). I slowly went from 42-43-44-45-46-47-48-49 RPM and once I got close to 50 she would start sounding rough, and ease back to 42 RPM on her own even though I had her at full throttle. At first I thought this could be a fuel restriction issue, so I decided to do some quick tests. From neutral I hammered the throttle down, and she seemed to "get up and go" on plane with ease just like she normally does. Weird. Once I was at cruise speed (40-41RPM) I hammered the throttle down again to WOT and was able to get 52RPM.
Did this a couple of more times and got the same results -
1) If I slowly increased the throttle up to WOT she would bog down on her own and run rough
2) If I hammered the throttle to WOT, she would stay at WOT and keep running as normal
Since I can hammer the throttle and run at WOT it sounds like its not a fuel restriction to me. From what Ive been reading this sounds like could be related to the O2? The sensor is new as of last year and was cleaned at the beginning of this season, 30 hours ago. Im going to go down to the boat today and clean it out and see how she looks but just wanted to get everyones opinion before I start tearing the fuel system apart again!
Thanks!
Thanks!
