Im Lon 2
Thread starter- Joined
- Nov 29, 2013
- 123
I have a little oxidation on my boat and I'm wanting to try remove with a compound and cutting pad. I might of course end up having to sand using 1500 grit, but I'm not sure it is that bad.
The problem I'm having is there are so many different products from compound, polish, cutting pad and polishing pad, you can spend days (I have) on Youtube researching..
I had planned on purchasing a 6" orbital sander/polisher, but what is a good compound and cutting pad combo you guys are using that seems to work well?
Compounds
Meguiars M105 Ultra Cut
HD Uno,
Marine 31 Gel Coat heavy-Cut Oxidation remover
Pads
Wool Pad (will this even work well with a Orbital polisher?)
HD Heavy cutting (yellow) pad
HD Cutting (orange) Pad.
My first thought was to do a 2x2 area using the Meguiars M105 compound with the HD cutting pad (Yellow), then work my way down to a HD Polishing (Blue) Pad with Meguiars M205. Following that up with a Wax.
Thanks
Compounds
HD Uno,
Pads
Thanks
