Paddle wheel Houseboat restoration
NSBCraig
Re: Paddle wheel Houseboat restoration
Man I'm so glad your still at it!
Who did your welding? Did you ask some local welder? I think I'd have to at least get one involved (into the project) even just for feedback.
I fully understand you asking but I think you already know the hull is not gonna leak. or it is...
If your all set up and that's where your gonna do most of the work then I say carry on with in.
and post pics!
mthieme
Now that's what I call a tow vehicle!!!:D
erikgreen
Hmmm... looking at all that rust, I hope you sandblasted it out, checking for thin hull plates and replaced what was corroded. I'd hate to think you had plates that would hold water but not stand up to impact of any kind.
You can in fact patch a steel hull in the water. It's possible to weld in the water, although it's a specialized skill and will cost a fair bit of cash to hire someone to do. If a leak developed I'd personally just plug it from the outside with a "soft patch" IE boards and plastic or similar. Then you wait until the inside dries and patch the hole from inside with a piece of steel. You can use a material like 3M 5200 on the outside to seal the hole. Then you wait until you can beach the whole thing to do a permanent repair.
Or, there are tricks you can pull depending on where the hole is. If it's in a chine area or on the side, you can maybe arrange to get the hole out of the water long enough to weld it. You'd need a big lift bag on the side of the boat under the hole... any hollow item like a big fuel tank, a series of 50 gal drums, or whatever would work... you basically use them to raise that side of the boat up to get the hole out of the water. You can also lower the other side of the boat via weight, cables to anchor blocks, or whatever. It's tricky, basically you're inducing a big list to get your hole dry long enough for repairs.
Big ships have been repaired in the water a long time, so there are a lot of ways to fix metal boats in the water. I'm betting you'll find out that most of them are more hassle than just taking your best shot at leak fixes then pulling the boat again if needs be.
On the bow thruster, there are a lot of types. The cheapest is a big trolling motor on the bow with a remote control at the helm. Most of the commercial units run on either electric power or hydraulic. The big ones in ships have their own motors. Basically these are props mounted across the beam inside a tube that penetrates all the way through the hull. For your use I don't know exactly how you'd do that, maybe mount the thruster tube externally on the bow under the waterline.
Any reason you can't put the boat in the water to check for leaks, and if it's good then start building the interior on the water?
I wouldn't put the interior in until you're 100 percent sure it won't leak....
Erik
legoman67
we want pics!!
sounds like you are getting pretty close to the easy/fun part now(the cosmetics/interior design)
JaSla74
This is a cool project. Glad to see you're still at. Mardi Gras will definitely be one of kind once she's afloat.
It also makes me feel a little better about the cash I've dropped in my project. I can point to your rig & say "See honey, I'm not all that crazy."
jennis9
Hillabs
great to see you pop back and give us an update!
Andy in NY
i just stumbled upon this jewel and cant wait to see the outcome.
dan bateman
being in navy 10 years. never had foam or coke bottle on them. had damage control kits pieces of steel braces and wood fig to drive in if the hull below water line is empty wood plywood and 2x4 brace will get you home. and a good bildge pump. dan bateman also at that pressure you can probleyput your hand over it or even a rag.
redfury
wicked undertaking! As long as the hull plating is thick enough, and you've filled it up enough times to be able to determine that you aren't getting any leaking or seepage from the hull, I'd put it in the water.
Now, depending on how you build the rest of the boat, you might be able to set it up so you have access to under the floor for inspections/repairs if need be.
