Re: Paddle wore out, need help with outboard !!??$$$
Paddleboy, take a ten penny nail and cut the head off. Stick it in the end of a spark plug wire and hold the sharp end of the nail 1/2" away from a CLEAN engine ground and have a friend crank the engine. If you see spark, it should be a hot lighting like spark. No spark, pull the big red connector and jump the starter solenoid and look for spark again.
Couple questions......is this engine new to you or have you had it a while. If you've had it a while, how good did it run....what rpms at WOT?
