Paint for aluminum boat?
jimp37
Hi, I have a 14' aluminum boat, currently has paint but considering repainting. Used in saltwater and fresh. Not stored in slip. What type paint do I use, and is the entire bottom typically painted as well? Above waterline paint is mostly in good shape. Below waterline there are some bare aluminum spots and some paint.
Woodonglass
This might be of interest...Paint Your Boat with Tractor Paint...Say What!!!
Watermann
I would strip all the paint on the boat and wire wheel off any corrosion you find before moving on to primer and painting. I've used rusto topside and tractor paint. They both are the same and with hardener added is pretty tough stuff after fully curing.
Ayuh,.... I'd save a Ton of work, 'n sand the existin' paint Smooth, 'n repaint it,.....
Then ya just gotta spot prime the bare metal, aluminum bein' such a pain in the a..... to prime,...
gm280
Aluminum is a different beast to paint verses other materials. So absolutely remove all of the paint that is there now. Reason for that is because if some of that paint is bad, flacking or corroding, it makes me wonder about the remaining paint doing the same after you put your effort to repaint. So I would remove all the paint from the hull. You can accomplish that via strippers and manual sanding. Then after all that hard work is complete, you have to use a quality type primer for aluminum surfaces. That means either Zinc Chromate primer first OR some quality type etching primer stated just for aluminum. If you ignore that step, look for the finish pealing down the road. After doing the zinc chromate primer, I would follow that up with a very good epoxy sandable primer on top of the zinc chromate. And here is where your final finish gets its flawless look. If you are simply looking for just a simple painted finish, then do a cursory sanding and move on to the top coat. However, If you are looking for a very nice head-turning finish, block sand the primer until it looks and feels perfect. This is the stage of painting you make the world of difference in the finial look. One thing to understand regardless which direction you choose to go, there is no paint that will cover over any flaw in any primer coat ever. So if you can feel a pit, divot, gouge or flaw in the primer, it WILL show up in the final paint... JMHO!
jimp37
Ugh..sounds like a lot of time and effort for my 1973 14' aluminum boat. I thought I could just spray over at least the top half but hardly worth it I guess being it's only used for fishing
Woodonglass
Here's what I have discovered after spending Hours and Hours on Prepping and Painting my fiberglass hull. I WAS DUMB!!!!! 30 mins after I splashed the boat I didn't give a hoot in H. E double Hockey Sticks about how the bottom of my boat looked!!!! 3 years later I still don't. I think Bondo is 1000% correct. Sand it down as best you can Prime the bare spots with some Self etching primer. Roll on some Rustoleum Paint with some added Hardener and GO FISHIN!!!! I'm betting the Paint will last longer than you think and I KNOW FOR SURE the fish won't care if it looks Perfect and I'm bettin you won't either.:D;) But...I AM just an Old Dumb Okie so there is THAT to consider!!!
hadaveha
I am painting my aluminum boat now, paint is turning out great, but and its a big but I didn't spend enough prep time, so any area than wasn't smooth is showing up with the really glossy paint two fold, mine is just a fishing boat so it will be fine, but when I do my bigger boat you can bet your back side it will be smooth as glass when I paint
gm280
jimp37, obviously there are lots of different ways to paint a boat. Please don't get discouraged with my elaborate instructions in my previous post. Not knowing what you are truly looking for, you can just as well follow Bondo's suggestions and do a cursory sanding of what is there now and roll on some Rustoleum Paint as Woodonglass suggested as well, and go fishing. You can even add a hardener for a little more life as well. I was giving you the procedures for a very nice finished top quality paint job that would last for years. But there are other cheaper and less elbow grease ideas as well. So don't give up. Try whatever YOU think will be okay for your project. After all something is better then nothing...
jimp37
Yeah I really didn't want to get too elaborate due to time constraints { and loss of fishing time! } but I guess my main concern is applying the wrong type paint to my aluminum boat. Seems awfully confusing these days with what paint bonds to what surface and which paint will eat that surface and what primer is no good for this type paint, etec, etc. Just don't want to apply paint that will have some strange metallic reaction and begin eating aluminum lol!
robert graham
Yeah I really didn't want to get too elaborate due to time constraints { and loss of fishing time! ** but I guess my main concern is applying the wrong type paint to my aluminum boat. Seems awfully confusing these days with what paint bonds to what surface and which paint will eat that surface and what primer is no good for this type paint, etec, etc. Just don't want to apply paint that will have some strange metallic reaction and begin eating aluminum lol!
On my aluminum jon boat I use the flat camouflage spray paint from Walmart....the ultra flat painted surface sorta hides any scratches and imperfections....the flat camouflage paint comes in several colors of khaki, OD green, dark green, etc....but mostly for an outdoors/camouflage look....I use the same paint on my VW rail buggy....everything mostly green. I don't paint my aluminum canoe...use straight bleach/Clorox, a brush and a garden hose to keep it bright aluminum....
Woodonglass
Well THIS link will tell you how to use the Tractor Paint, for CHEAP and it'll stick to your boat with NO ISSUES!!!
pckeen
If your paint is in good shape, scuff-sand, spot prime, and repaint over the top. My current project took me.....quite a lot of hours to strip - I had no choice, becuase there were about five layers of house paint on it - but I don't reccomend the experience of stripping.
