boatguy94
Thread starter- Joined
- Jul 29, 2009
- 520
Since I will be painting my Starcraft, along with many others, in the future I thought it might be a good time to get opinions on what paint/primers others have used or are using and how they are applying it.
If you have already painted your Starcraft post what your thoughts on how the paint is holding up, and how it was to apply. Pictures are welcome
I know that there are tons of resto threads out there with this stuff in them, but it might be nice to compile it all into one thread for anyone looking for a reference later on.
Update 12/16/10:
Here is a link from Jasoutside's resto thread about rusto on a car and how it has held up in the world. Not how you would apply it to a Starcraft, or any aluminium boat, but a good refrence.
http://www.rickwrench.com/index79master.htm?http://www.rickwrench.com/50dollarpaint.html
Also so that this is at the top of the thread I have quoted MichaelP's researched paint process. This will change i'm sure, but it's a start.
Update 12/16/10:
Here is the process that looks best to me at the moment.
1) strip (not necessary to remove all paint)
2) scour entire surface
3) degrease with lacquer thinner or similar
4) wash bare alum with 50% H20/50% vineger and let dry
5) tack cloth
6) 1 coat Etching zinc chromate primer
7) 1 coat primer that?s compatible with top coat
8) light sand then tack cloth
9) top coat with either enamel, 1 part epoxy (or what ever you can afford) (2-3 coats)
rev b 12-09-10
This might be a starting point for us. We can modify this as we go.
