OHfishing
- Joined
- Apr 28, 2006
- 182
I sanded down my boat and made some glass repair, the hull is now in mint condition ... after I repaired the hull and smoothed it all out...I gave the boat 6 coats of interlux 2000e barrier/primer ... which dried to an eggshell texture and is meant to keep water from soaking into the glass ... now...I am ready to paint... I got some interlux topside paint (white) and I applied it over the interlux 2000e ... I used a roller for the application of the FIRST coat...the paint is very bright and very white and shiny... considering i used a roller im ver happy with the first coat....however I have some hair from the roller in the paint...my question is... if I use some wet 3M microfilm can I remove the hairs andretain the shine? after I smooth it out I will be adding possibly 4 more coats...so I may need to repeat the process a few times ... how do I get the most out of this paint job? how do i remove the hair?
