Paint Thinner for fiberglass prepping
BoatingCop
I know you're supposed to use acetone after you sand your surface down that you are going to glass to, to clean it. I have paint thinner at the house, which is much cheaper than acetone. Is it ok to use paint thinner for prepping a surface? Thanks
Eric
halas
Re: Paint Thinner for fiberglass prepping
For a final wipe-down I think it is a good idea to to use the solvent that the manufacturer recommends for thinning the material to be applied.
Anything else could leave fine residue rejecting the applied layer. :mad:
WizeOne
Paint thinner is oily. Do not use it.
Bob_VT
Acetone is also used to thin fiberglass resin before it is set up..... it mixes with fiberglass but has no effect of dried fiberglass except as a cleaner.
I believe walmart carries it too and it is not too bad for cost.
Ayuh,...
Mineral Spirits,.. Aka; Paint Thinner doesn't really Flash Off,... It kinda lingers...
Acetone will Flash Off leaving Nothing before you're even done wiping...
rtpassini
i use 90% IPA or a tack cloth
