paint window frames
crankbait cowboy
restoring a 1973 starcraft 18 ft ss and would like to paint the window frames and possibly some other trim like rails and aluminum trim black. wondering if any of you have done so or ideas or suggestions . can i get it to stick and hold up.
thanks
GT1000000
Re: paint window frames
Aluminum??? Good scuffing/sanding/prepping to desired level of finish***, light coating of Zinc Chromate Primer, good primer base, then topcoat with choice of color...
Have fun!
***By desired level of finish, I mean the more perfect top surface you want, the better your preparation has to be...the final top color coats are not only a reflection of the world around us, but also a reflection of the surface they are applied to...
