thepotroast
Thread starter- Joined
- Feb 28, 2009
- 91
I just picked up this boat over the weekend. Specs:
2004 Triton 16' Aluminum (163 Sport)
2004 Mercury 60HP ELPT0
Weight of hull/motor/fuel/gear/passenger - 1500lb
It's using a Mercury BlackMax 10 3/8 x 13P prop
Speed on GPS 40MPH @ 5000 RPM
I am at sea level, run in fresh water.
The previous owner painted the lower unit of the motor with a marine based paint, which of course covered the prop. The prop is in good condition, but I believe that painting the prop probably impaired some of the motor's performance.
I want to buy a new prop for it, even if it's the same diameter and pitch as the current one, just to have an unpainted prop.
The boat will be used for bass fishing, and cruising on the lake. Possibly the occasional tube pull, but mostly I want to have top speed and performance on this setup. I ran a couple of 'wizards' online, and was getting some 10 3/8 x 14P (for aluminum) and 10 1/2 x 14P (for SS) suggestions for it.
It seems that the prop that is on it right now is a good 'median' prop, a mix between water sports and performance....I want to lean more towards performance...but also just putting a non-painted prop on it.
Suggestions?
Suggestions?
