While I have the outdrive off of my Holiday I want to paint the transom. The paint I am going to use is the rustoleum metal paint. I found this Rustoleum product at Lowes this weekend:
http://www.rustoleum.com/CBGProduct.asp?pid=523
My hull has what I believe to be the original paint plus the "touch up" the previous owner did with a rattle can. He did not cover anywhere near completely. The surface is mostly smooth. I figured I'd use 150 grit sanding discs to do a quick ruff and scuff. Beyond that starting step I need the painting gurus to step in with some advice.
Since I am not going down to bare metal do I still use vinegar as an etchant before priming?
Do I use the aluminum primer that I linked to or do I just use the standard quart cans of primer that rustoleum offers?
Do I use a coat of the aluminum primer first followed by the other rusto primer or just two coats of either one? Which one is best for that application?
Thanks in advance for the help.
