Painting boat
Fireboy197
Looking to repaint my 1982 14 foot sears game fisherman fiberglass tri Haul gelcoat is gone looking for some advice On prepping and painting not looking for a showpiece but looking to do a nice job
Chris1956
The "Roll and tip" method of painting gives a near sprayed look and is real easy. Home Despot has a oil based alkyd marine paint by Rustolium. I have not tried it, but it looks to be heavy duty. I'll bet it would roll and tip real well, and it is $15/qt, versus $40/qt for Brightside marine polyurethane paint.
You should just be able to sand and paint. These two paints are for above waterline use only. I do not think they need any priming for use over solid fiberglass.
RMClark
My boat is a 14' Lund aluminum v-hull. Got it last May. Looked like this when I picked it up:
Like you, I wasn't looking for a "show piece". Just decent, and not expensive. I read about an RV trailer rehab that used Krylon Farm and Implement paint with a hardener added. They also used the "roll and tip" method.
So I stripped the boat mechanically with brass wire wheel and abrasive disc.
I still need to clean up the bottom, but that's a project for next winter. Here's how it sits now:
I bought the paint at a local auto parts chain store. I used half of the quart to do the whole boat. Paint was $15. Total cost of the job, including rollers, a brush, and some thinner was less than $40.
gm280
Just MY opinion. I use primer on anything I want the paint to last for any amount of time. Primer is made for a reason. If you ignore it, the paint could still work out b. But using primer allows the top color coat a perfect surface to adhere to. And I like to use the same manufacturer of the color top coat I plan to use as well. They were designed to work perfect with each other. But that is just me.
RMClark
Didn't you need to prime the aluminum?
When I researched the Krylon versus other farm and implement paints, I saw that is labeled on Krylon's web site for direct to metal application, and so that's what I chose to do. I had removed the old paint using abrasive wheel and wire brushes, and then wiped down the surface with acetone before painting.
We'll see how it lasts, I suppose.
Fireboy197
