Re: Painting my transom
Is this an older boat, or fairly new? <br />You can use an epoxy, then primer and paint over it. Its better if you can get to all of it so you can seal all surfaces of the wood. If you can't get to all of it, don't seal off areas where water needs drain out from between the wood and aluminum. You don't want to trap water and create a rot problem you didn't have.
