Painting Observation
mtnrat
When applying epifanes 2 part polyurethane I found that I would get much better flow in the evening when it was cooling down as compared to the morning when it was warming up. At both times the temperatures were pretty close. Evening applications had no tipping marks while the morning they were a little more evident.
mtnrat
Re: Painting Observation
Ah ha. There in lies the problem. I was sent spray reducer instead of brushing reducer so how about 0 %. :) or :(
Tail_Gunner
You can use either, try 10% it will slow drying time's and get you a smoother finish.
gcboat
The spraying reducer will flash off a bit quicker than the brushing version. Stands to reason as you can spray quicker than you can brush. Do what tail-gunner recommends - you should be O.K.
mtnrat
I will test a small amount. Thanks. But... I am already set up with lots of light for when it starts to get dark :)
Tail_Gunner
Im to lazy or tired right now, search "painting with perfection" get the roller i posted forget the tipping and you will be amazed. Of course test the paint first, it's damm well worth your time.
mtnrat
I am using those rollers. I gleaned that info from your painting thread. Will try a little w/o tipping to see what happens.
mtnrat
Wow, that worked!
