painting outboard
ward cleaver
quick question on painting outboard: instructions on can says paint needs to be between 70 and 90 degrees F. Does outboard need to be in that range also, or does it matter?
Chris1956
Honorary Supreme Mariner
Re: painting outboard
It is much easier to spray paint an object in warm temps. You can use lots of paint w/o any runs.
It will be hard to get a good finish if the OB is cold. The paint may not dry, and will run very easily...
ward cleaver
thanks. i assume it would be better if the air temp was around 70F as well.
Chris1956
If you can warm up the paint and the object to be painted to room temp, the air temp will be less of a factor.
5150abf
Ya get the can warm and use several thin coats instead of one heavy one, eliminates runs and gives you a better finished job and leave a good 20-30 minutes between coats.
You of coarse scuffed the old paint with some 400 grit or a Scotch brite yes, that would be the minimum prep before paint, if not it will be peeling in a couple months.
