Painting Question
Re: Painting Question
fyi, iopened your link and it took me to the home depot site and it said it was unavailable.
ne7800
you can paint aluminum if you use a self etching primer any auto suply store that sells paint should have it
Ayuh,...
I'm sure it can be done,...
But,..
Those parts are Anodized,... You'll need to strip it off with a SSteel wirebrush,+ Then prime,+ paint....
Otherwise the paint will just peel right off,... Paint won't stick to Anodized surfaces...
gcboat
Don''t remove anodizing, just prime or etch it with Zinc Chromate (''green'' outdrive primer) or Oxalic Acid (Aluminum ''brightener'').
