Panther 55 trim/tilt
keithet
I posted this in Merc, boating and Yamaha since the motor is Yamaha and the controller is merc. I apologize in advance if I have broken any forum rules.
I have a Yamaha 40 hp 4 stroke with a Panther 55 tilt/trim unit. I am moving it to a small pontoon boat. The brand new, never been the water pontoon has a Mercruiser Binnacle control with a two way button on it for tilt/trim. The Panther control is a two button three wire switch. Is there any reason I could not use Merc switch to control the Panther? I assume I would have to splice/wire in the Panther plug to go to the wires from the Mercruiser control. Thanks for any advice you can give me.
Keith
rodbolt
Re: Panther 55 trim/tilt
no worries.
however the panther unit wasnt OEM for either merc or yamaha.
but it still uses a simple DC circuit to activate the relays/solinoids for trim control.
without a diagram of the panther unit I cant tell you how to wire it but they are simple.
