Park/Tail lights no longer working on road king trailer with brakes
nastyquedawg
About two months ago i put new LED lights on the trailer. Last weekend I hooked the 5 flat plug from the trailer the round adapter on my truck and it flickered then the park/ tail lights went out. Pulled the flat plug off and noticed there was no rubber between the male park light plug and the female ground plug coming from the trailer. I also noticed a little smoke and the wires got hot. So I am assuming they touched. So I replaced the plug on the trailer and purchased a new round adapter for the truck and the park lights still dont work. The brake and signal lights work on the trailer. Any ideas?
04fxdwgi
Re: Park/Tail lights no longer working on road king trailer with brakes
Recheck your wiring and ensure it is correct...... Do the lights on the tow vehicle work? A short on the plug should have popped the fuse on the truck's fuse panel to protect the wiring.
nastyquedawg
This incident originally occured when i was driving my tundra and the park lights on the tundra never went out. When i took the same trailer and hooked it up to my 93 chevy it blew the fuse twice. I hooked the green/brown wires to a direct 12 volt source and after plugging it up nothing lite up but the wires got extremely hot. Did the same approach with the yellow/brown wire and everything worked fine.
cribber
The only reason wires get hot is too much current... means you've still got a short to deal with on the trailer. Here is a link I use anytime I need to do any work on a trailer lighting setup. http://www.etrailer.com/faq-wiring.aspx
T_Herrod
If your park lights on the Tundra never went out then you have a separate fuse for the trailer lights. As far as the green/brown wire getting hot,,,, that would indicate a short in that circuit. Find the short and replace the fuse and you should be good to go. Good Luck
