Re: Part Number and No Spark
I did not answer your question about the distributor and rotor yet because you indicated everything was in pretty bad shape. If we get the amplifier going we will move on the the coil, distributor, rotor, hV wiring to the plugs, and make sure the points are set correctly and providing that very short dual point opening that this system provides. You can be the points in the test above by closing and occasionally opening the circuit into the module. My test after I read it sounds very complicated and it is not. It really could be described as an electronic simple relay with the points being the pushbutton (normally closed) and the relay which is normally providing 12Vdc opening up. This is the first crude electronic system and does not use capacitive discharge to power the coil. I guess thats why they called it an amplifier. Those of who work with electrical devices would say today that is a very non-linear amplifier. In fact it is the simplist type of all: It is either on or off..Why its digital. So tell every body you have a binary output solid state digital, one or zero, ignition. system.... Ha
