Likesspace
Thread starter- Joined
- Aug 25, 2016
- 17
I have a model #50ELPT-4S Mercury outboard that I need to purchase some parts for.
The problem is that the tag that shows my serial number is in very bad shape and I can't get a good read on the entire serial number.
Here is what I can make out: DG---422. There are numbers between the DG and at least one number after the 422. But unfortunately the rest of the numbers have been worn away from years of use.
Under the model number, (50ELPT-4S) I see the number 2000. That leads me to believe that I have a model year 2000, motor.
I need to purchase a thermostat, thermostat gasket and water pump impeller or water pump kit for this motor.
If anyone can tell me the correct part numbers for these items it would be greatly appreciated. I'm new to working on outboards so I don't want to order the wrong parts.
Also, this outboard does have the Bigfoot lower unit. Just in case that makes a difference.
Thanks in advance for your help.
Dave
Dave
