Part Number Please
Marianne
My spakplug was cross threaded so I bought a helicoil kit to repair it. Last outing I checked and there was oil around the helicoil. I guess that didn't go well. I thought I'd try to replace the section of motor the spark plugs screw into. If anyone could provide me with part number and I guess I'll need gasket too. Finally if you can tell me out of 5 wrenches how difficult it might be to do ( I did my own carb overhaul - 4/5 wrenches).
Details
1987 Johnson Evinrude 30 hp (no trim - I wish)
Mod # CJ30ECUB Ser # C7480572
Underside Stamped 331473 D1
Cheers,
M.
Chris1956
Honorary Supreme Mariner
Re: Part Number Please
You can try a solid insert to repair the threads. You drill and tap the cylinder head and install the solid insert with some epoxy to hold it in place. Works much better than a helicoil, IMHO.
seahorse5
Details
Cheers,
M.
Use the online parts book furnished by Evinrude
http://shop2.evinrude.com/Index.aspx?s1=f0ejl1i0kbmfaisaa3lq0jvvb4&catalog_id=0&siteid=1
Marianne
Can anyone verify if a 1983 35 hp johnson cylinder head work ?? The seller tells me his motor overheated & lost compression. Should I stay away from it or is it a good fix ??
Please advise,
M
