Part of outdrive turning white... Pics inside.
chrisf695
So I have a powerplay integra with a 408sbc with a alpha SS. I can tell that my drive is over heating a bit but not sure how bad. Should I be in the market for a drive shower? Would that fix the problem? I change my drive oil every 15-20 hours. I do run a 4 blade rev 4 that gets me 66-70mph depending on load.
NHGuy
Re: Part of outdrive turning white... Pics inside.
I'd think a drive shower would be a very smart thing.
What drive oil do you use? And how does it look after it's removed?
If you ever have a gear failure get those uprated cogs. 408 SBC...I guess you usually run out in front when you choose to!
chrisf695
I use merc high performance and the oil looks good. Not burned up. Whats meant by the "uprated cogs"?
