daydreamer1252
Thread starter- Joined
- Aug 7, 2007
- 212
Ok have a thought and the thought may well be completely wrong. Or I may be as they say all wet....
1984 17' Galaxy bowrider. Floor was rotted and from all I can tell the stringers are solid.
Transom is rotted from one third of the way up the cutout for the outdrive to the bottom. The rest of it checks OK, drilled test holes and checked what can be seen around the transom cutout and this appears to be the only damage.
Now the question:
Can one replace the damaged portion only (a horizontal "splice") and still end up with a solid and safe result? I am all for saving time and money but won't settle for a transom that is only 60% (a randomly chosen number) as strong as it could/should be.
If this can successfully be done is plywood or seacast or some other material the way to go?
As always all help and comments are appreciated.
Now the question:
