Partially damaged spark plug hole on 115 optimax
dan the gman
What is the best method of repairing the threads on a spark plug hole on my 6 cylinder Optimax? It’s the upper cylinder on the right bank. The first few threads are looking damaged and the plug won’t start to thread. The angle is kind of challenging and I’m concerned about having enough room to work. Thanks for any suggestions.
ONERCBOATER!
Helicoil...had to do it to 1st outboard I ever owned....line 35 yrs ago.... some one that looked an awful lot like me may have been ham fisted as a teen and might have overtightened a sparkplug on a 1957 johny and completely stripped the threads....then started it and was surprised when i heard a loud pop and the plug escaped the block.
I was not popular that weekend, a friend's mechanic helicoiled it and saved my bacon.
I don't recommend the overtightening part but I do strongly recommend helicoils and casesavers.
Sean
stresspoint
Something like this might solve the problem.
You'd have to get one with the right threads.
this . remove bits off the motor till you can get a good strait line to the plug hole ,
run the chaser with some grease to catch cuttings.
no short cuts , do it right or you will do more damage.
QBhoy
Above advice is the way to go…
On a side note…is she definitely a 115 and a v6 ? Not sure I’ve been aware of such an engine…but I’ve been corrected plenty of times on here before !
airshot
If only the first few threads are damaged, another option is to remove the head and run the tap/ thread chaser from the inside out. This will keep all the threads in alignment while correcting the damage. When you come in from the outside, you MUST have the thread chaser in perfect alignment or you will have a mismatch. All depends on how bad those first few threads are actually...
