parts compatability
mudslinging79
i have a chance to pick up a complete motor for cheap and was wondering, can some parts from an evenrude fastwin 15 horse be used on same model only 18 horse? i know carbs probably wouldnt, im looking at lower end, and some of the internal parts such as linkages, etc.
1946Zephyr
Re: parts compatability
it depends on the year of the 15 hp. The 1955 and 56, should be mostly interchangeable with the 18's. Prior years will have more mechanical differences.:cool:
mudslinging79
the 18 is a 1965, the 15 is close to it if not the same judging by the motor covers... if they were side by side they could be twins
F_R
Honorary Supreme Mariner
You will find some parts are the same and many are not. It would be a matter of exactly which part are you interested in.
The 18 would be a larger displacement engine and thermostat controlled cooling. It has a fuel pump instead of pressure tank feed. Carburetor would be bigger bore, but use more or less the same kit. Ignition and water pump similar. Gears might be different..would have to check on that.
EDIT: Oops, just reread your post. A 1965 is way different looking than an earlier 15. Better check the year.
mudslinging79
both are about the same year, side by side they could be twins. and i am looking at parts like the lower end, tiller/controls etc. pistions i know would be different as well as carbs...
