Parts Question
Adam76
OK, I'm going to be changing my bellows and anything else that needs to be replaced once apart. This will be my first time doing this so I want to make sure I have everything I need it seems like there is alot of different kits with different parts. I was going to use the ehaust tube instead of the bellows, so is it best to just order each bellows by itself or is there a kit that has the ehaust tube instead of the bellows. I'm also planning on changing the impeller, so which seal and gasket kits will I need once everything is apart, some of this is confusing to a newbie. I have a 94 350 5.7 Alpha one. Any help appreciated.
Thanks
Adam
Re: Parts Question
Ayuh,... When goin' that deep,...
I'd have on hand the bellows, the shift cable kit, 'n a water pump kit...
Ya can throw i the trim/ tilt sensor/ switch too, if yer inta those things,...
I ain't...
'n don't forget to check the alignment while yer in there...
Adam76
Re: Parts Question
Thanks, will these kits come with all the seals and gaskets I'll need to replace. Also is the shift cable something that should be replaced every so often or am I looking for something specific in the cable that shows it needs to be replaced.
