patching underwater screw holes
Twidget
I was crawling around under the boat and noticed a lump. The lump turned out to be a screw, with a rubber pad surrounded by sealer. If I were to remove the screw, would Marine Tex be the product to use? Also, would the area need to be painted after the patch. <br /><br />This is definitely an underwater portion of the hull(starboard sice, bottom, near stern). The boat is on a trailer most of the time.
Dunaruna
Re: patching underwater screw holes
Might need to do a bit more research such as: Is the screw doing something useful like bonding the fuel tank (thats what I've got). Is it leaking? Is it already a reasonable repair?<br /><br />Aldo
crab bait
yeah, like DUNA said..<br /><br />but yeah,, all things being equal,, marine-tex would be the ticket..<br /><br />grind away alittle surround area.. even 'divit' grind the hole alittle.. all so to have a good bond an alittle thicker at the hole.. as so not a thin surface coat..<br /><br />no need to paint.. since no uv rays..
Tinkerer
A countersink bit gives a nice hole that is shaped for water pressure to push the fill plug towards the hull with ever being able to push it through.
Twidget
Thanks for the replies advice guys. <br /><br />It seems to be holding up. Looks like the used 5200 on it. I dont think it does anything structural, no built in gas tank. <br /><br />Its near a place where the seats are screwed in. As near as I can tell, with the spacing, its through the hull and into the floor.
