arabiflora
Thread starter- Joined
- May 18, 2003
- 4
I have to admit that I probably did a crappy job of winterizing last fall (although not any different than in the previous 5 years that I've had the boat) and now I'm paying the price. I have a water leak on my '78 Mercruiser 140 hp. I had it running on muffs for only a short time last weekend, saw the leak and shut it down. The water continued to drip for a minute or so longer, giving me some time to look for the source. It was dripping OFF the bottom of the exhaust manifold near the center. However, if I put a shop rag above that location, between the manifold and the block, the dripping immediately stopped, so the leak is apparently higher but in that vicinity.
My first inclination was to pull the manifold and look for cracks (hopefully not in the block), perhaps be able to seal with epoxy. However, it occurred to me that the actual crack might be very small and hard to find (although there was a fair amount of water coming out when it was running.
So my question is this: Will cracks in the manifold or block be readily apparent, or should I invest more time in localization before tear-down?
Also, and relatedly, in reviewing posts here I came across suggestions for a coolant system pressure check. If that's a DIY project, how is it done using, say, a bicycle pump or compressed CO2?
Finally, I'll also note that the overwintered gas (~5 gal) was significantly mixed with water. Could that conceivably be related to the water leak from the manifold/block?
Thanks in advance for any thoughts,
Scott
Scott
