PDF Links: Technical drawings and manuals galore! (Mercruiser only)
lowkee
In doing some searches to find the exact placement of the front engine mount of my 3.0L I found this, which should help others in my predicament.
http://www.brunswickmarineemea.com/...rcruiser/2001/gasoline/stern drive/862917.pdf
That PDF shows every measurement you could ever want to know about the engine placement. Thank you Brunswick Marine and Google!
What I didn't know, is Brunswick has a full search engine for manuals, which is awesome!
Search results
That link brings you to every technical drawing used for any mercruiser engine and outdrive installs with direct links to the PDFs (and sometimes even AutoCAD DWF files).
Here is a link to the PDF of a transom hole template for Alpha/Bravo drives.
http://www.brunswickmarineemea.com/filereader/file/pdf/7/enen/mercruiser/2009/transom/79135006.pdf
There are hundreds of PDF files for everything Mercruiser related here!
Here is a 3.0L User and maintenance manual:
http://www.brunswickmarineemea.com/...uiser/2005/gasoline/stern drive/860168051.pdf
