Re: Peanut butter.
Northcoast, I would bed the stringers to the hull. If the OEM used foam, I would replace it. If not, I would consider adding it. Foam adds a heck of a lot of strength and no weight.
If you do not bed the stringers to the hull, the hull will flex a bit with each wave. I think the hull could crack under this circumstance. I had a hull crack on my SeaRay 19 BR. I believe it was not foamed properly, allowing the FG to flex too much. It cracked on a strake, which is one of the strongest points on the hull. Luckily I didn't sink.
BTW the stringers were intact. I reinforced the crack in the hull with lots of glass, added a stringer which bisected the strake and doubled up the original stringers for good measure. I also refoamed it.
