pee hole
mcruea
how can i add a pee hole to my force 125, or is it posible to do that
mcruea:confused:
mcruea
Re: pee hole
thanks for the posting , i remember seeing this one but i coundnt find it, so thanks marty
Gamblerman
Re: pee hole
come off of the head with hose and use a tire valve stem drill a hole in the lower cover just off to the side and pull the valve through this hole with the fat round end on the out side. Now remove the inner stem so the water can pee out. This will give for a factory look and it looks clean at the same time.
Shawn
baxtr
Re: pee hole
Most of the others work but look like ****
Shawn
Wow, I actually had to go out and look at mine again just to make sure it didn't look like ****, seeing as I didn't use a valve stem and all.
It Doesn't :)
Gamblerman
Re: pee hole
Sorry I did not mean to step on feet.I was just saying most of the guys like a clean look. I have seen some ugly setups before.
rudedude
Re: pee hole
I used a rubber gromet and put my tube in that. It looks like a pro did it. I followed OLe baxs routing of the tube and it is a very clean look to it.
Tire valve ? Post a pic of that will you please?
baxtr
Re: pee hole
No feet stepped on :) just giving you some ****
I believe the tire stem luck used was for a grommet like yours, just removed the valve and feed the tubing through it. Pic would be nice to post though if you got one
rudedude
Re: pee hole
They use a rubber cromet with a little plastic nub moulded in it so the tube can be slipped on it. It comes out looking flush with the motor case. I let my clear tube come out about 1/4 inch, looks real clean.
I didnt want any type of metal touching the motor case because of the little extra rotting problem I may get later down the road.
Nice to see you BAX.:D
wayne h
Re: pee hole
although i am not against the added tell tail .. i feel it takes some water away from the motor .. i know i know but its my way of thinking so instead of the homemade tell tail .. i added a water pressure gauge to mine and can see it right at the captions chair just in case of anything .. i found it on ebay new in box for 7.99 although it was an older one it was new ..
Gamblerman
Re: pee hole
sorry guys I dont know how to post pixs but if you email me I will send to you:D
