Penetrating oils - anybody ever try any of those FREEZE concoctions from Loctite or
David K
Re: Penetrating oils - anybody ever try any of those FREEZE concoctions from Loctite
Get a torch that use MAPP gas. It looks just like a propane torch but is approved for use with much hotter MAPP gas. Not much money and even gets hot enough to do light brazing.
Dave
Butane pencils wont last long before refueling, just get a propane torch
bang4dabuck
I can pick up a Benzomatic MAPP kit for under $40 at Grainger. It is discontinued for some reason. That work ?
fishrdan
MAPP gas gets hot enough to melt aluminum so don't go hog-wild crazy with a MAPP torch. I melted a piece of aluminum practice brazing with those aluminum "welding" sticks. You can do it with a MAPP torch, just be careful not the melt the aluminum.
David K
That will work. As Fishrdan said, be careful. Treat it like an acetylene torch not a propane torch. It does get hot.
Dave
rolmops
I do use the cold stuff when trying to insert piston rod pins and it works great!
