Perco battery switch install
Jakem
Morning, ya shoot I was talking slave you are right. It's a ford 302, boat is a 1975. One wire is on the positive and one wire is from main harness on the 50 amp.
dubs283
Where is the wire that goes to the 50amp breaker?
I'm not sure. In the picture posted by OP it is definitely not installed as shown in the schematic you've posted which is the correct way
I was merely stating that OP's setup is (now confirmed) a Ford base and oem configuration has main B(+) connection to slave solenoid
Jakem
I've got her figured..all working now. Thank you
Wasn't disagreeing or figured you would know, just used your post to note to OP what should be there
and sounds like he figured it out
Great news
Jakem
Now should I install a bus bar for all my grounds. Seems it would tidy up my wiring
