Perfect pass stargazer install
86 century
Ensign
I was unable to find a thread on here on a pp install so here we go.
This going on a '90 supra bravura with the pcm 351w.
The 3.5" multiline display going in the dash.
You can replace either your speedo or your tach as the display has a digital tach and gps Speedo that stay on even if you are not using the speed control. I chose to replace the right side speedo. Was supper easy in my case. There is enough room to work without pulling the dash.
Throttle control servo mounts to a cooling or exhaust hose with supplyed clamps.
This is it for now the rest of my pics came out blurry.
86 century
Ensign
Re: Perfect pass stargazer install
This is one of those things that is so simple it's brilliant. You factory throttle cable is attached to the pp cable witch is mounted to the carb linkage.
With it set up this way it makes it almost imposible for it to run away as the servo can not take the throttle further than the manual cable is open.
