Perfect Seal
Downwindtracker2
What is it,I have never run across it. I have used Locktite 597??,the white teflon in a tube,and Nevr-Seize. I'm putting together a 7.5 from a couple of parts motors,a 76 and a 75. The two props a ,three blade and a two blade,came off easy and I hope for that again.thx
*EdC*
Re: Perfect Seal
Perfect Seal, is Mercury's brand name sealant. Good stuff.:)
CharlieB
Re: Perfect Seal
The closest description I can give is sort of like a mixture of the 'peanut-butter' sealant GM used on head bolt threads and the black NON-hardening aviation permatex (av-perm).
Merc uses PerfectSeal on most all gaskets, sealing surfaces and on many threads as a sealant, thread lubricant, and also assist in minimizing thread corrosion (NOT inside the engine). Johnson/Evinrude has a comparable product.
