Performed leak test. Got more than what I expected.
Tracker12
Removed foam early in the morning. Filled up boat with water, about 8 inches. Right away found 3 leaking rivets up front, 4 rivets down the middle, 1 hole in the center lower part of boat. Also found water coming out of Livewell port next to the boat drain. The last leak I found was pissing through the transom. Transom leak was right at the center, couldn't see the hole because the engine tilt and trim bracket was covering it. Right now I feel like not continuing with the project. I will have to lift the boat off the trailer to fix leaking rivets, get the crack welded and remove the engine to inspect the transom. Roughly how much time and $$$ will I need to continue. Pls help experts. See pics.
Tracker12
Re: Performed leak test. Got more than what I expected.
carribbean soul
zero $ get a friend to hold a 2lb hammer on the back (tail)of the leaking rivet while you hit the head with a hammer 4-5 good wacks should swell it up to stop the leak. also the last picture remove the jb weld and fix that properly, if you have to pay a welder do that.
Tracker12
So should I start removing the engine and get ready for a transom repair?
bonz_d
Only if you are up to the task! If so what are you waiting for?
Tracker12
I guess I have to some kind of engine stand and engine Crane
Tracker12
No fishing for me this year
bonz_d
Both would be nice but not absolutely necessary. How big of an outboard was on it?
Tracker12
Its a 75 mercury
