Perko switch on Aluminum Boat
thakang67
Hello to all, My question is where do I mount my Common ground stud for two batteries and my distribution panel?
Thanks for any suggestions!
I would suggest a battery buss bar, and keep the ground from making contact with the boat hull.
Ayuh,.... The motor's block is the common ground,....
thakang67
Is it ok to use the bolt that is holding the motor to the transom?
GA_Boater
thakang67
Okay thank you I will go buy a bus bar a install it. I would like to install it back where the motor is. Is it okay to mount it on the wood transom?
thakang67
Bondo, so the way I understand what your saying is to run an sufficient cable to a ground on the block of the motor then to a bus bar mounted wherever then connect my batteries to the negative bus?
GA_Boater
YW. A buss bar can be mounted anywhere convenient. The mount screws/bolts are insulated from the wiring studs.
sam am I
Using the transom mounting bolts is the same as bolting the ground to the hull, a no-no in an aluminum boat.
His hull by default should already be grounded/bolted to batt neg through bonding wires. My stock Merc would ground my hull via two very specific factory bolted on bonding wires that intentionally bond/ground (batt neg) the transom mounting plate/bolts. If my hull was alum. that is........
However, running current through the hull or any metals that are grounded via bonding such as transom/mounting bolts, etc. as mentioned above (or even the bonding wire/s itself) is a no no.
See post #2, SilverTip is correct in his assertion
http://forums.iboats.com/forum/boat-...-aluminum-hull
