Permanent magnet gear reduction starter...
Lou C Supreme Mariner Joined Nov 10, 2002 Messages 13,970 May 4, 2020 #1 Attachments PMGR Arco installed.jpg 189.7 KB · Views: 0 Last edited: May 4, 2020
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,415 May 8, 2020 #2 Ayuh,...... No doubt Lou,...... I've been usin' 'em for 'bout 5 years or so now,....... Life is much easier changin' 'em,......
Lou C Supreme Mariner Joined Nov 10, 2002 Messages 13,970 May 10, 2020 #3 Question: any idea why they include that foam gasket? I installed it but at the same time, can't really see a good reason for it!
Scott Danforth Grumpy Vintage Moderator still playing with boats Staff member Joined Jul 23, 2011 Messages 52,294 May 10, 2020 #4 NFC....... not all come with a foam gasket, and if your trying to seal the flywheel housing, the sheet metal cover has a drain hole on the bottom....
nola mike Vice Admiral Joined Apr 22, 2009 Messages 5,815 Jul 8, 2020 #5 Lou C said: Question: any idea why they include that foam gasket? I installed it but at the same time, can't really see a good reason for it! Click to expand... Ha ha Lou C , I just asked you this same question on another thead as I just got a PMGR starter for my swap.
Lou C Supreme Mariner Joined Nov 10, 2002 Messages 13,970 Jul 10, 2020 #6 I had called the tech line at ARCO asking if you should fab up a front mount for these starters (he said not necessary) I should have asked about the foam gasket, lol.
