Re: Pertronix on AQ125 help
You have to test it at the positive side of the coil, that connects to the power wire for the pertronix. This powers the amplifier in the Pertronix unit. The starter motor MUST be engaged and cranking the engine, as this will cause a voltage drop. ALL! systems drop voltage with load..that's why your lights dim when you crank the car/truck/boat.
The negative side of the coil grounds at the distributor. This is what causes the pulse to the coil. It's also the side the tach picks up its pulse. Disconnect this wire, and try cranking it also...a shorted tach will give problems also.
Points and coils don't care what the cranking voltage is. Spark is caused by the collapse of the field in the coil. That's why ballast resistors work with points and coils.
