Pettit ez prime and easy poxy 2 part paint
panamacitymustang
I'm almost ready to glass In my new deck. Can someone explain to me what is the preping process when using the ez prime and 2 part easypoxy.
panamacitymustang
Re: Pettit ez prime and easy poxy 2 part paint
Step 3 says use solvent to clean sanding residue. Is there a certain solvent I should use.
zool
panamacitymustang
Thank you. I just wanted to make sure I was going to get the correct solvent for the job.
Woodonglass
I used easypoxy on my boat and used a 50/50 mix of Acetone and Mineral Spirits. It worked fine for me.
panamacitymustang
Thank you I was hoping there was some alternative solvents I could use.
