Re: 115 or 140 jhonson help
The 115 should pull strong out of the hole compared to a 140 till you get into the upper rpm ranges-when the 140 will pull away from it. The differences between these engines are not minor. The blocks have different port machining, different exhaust, carbs, and heads. The 140 probably swings the next higher pitch prop.
