philips screw removed on lower unit
Hennysemitara
So i took out the wrong screw when i was changing my oil in the lower unit. it went back in easily. should i be concerned?
jimmbo
Keep an eye for seepage, often when removed the o-ring/gasket gets damaged and leaks
On a newer V-4 motor you can take that screw out all day long and put it back in all day long.-----It is there to prevent the pinion bearing from moving due to oil pressure build up in that bearing.---Replace the o-ring on it if it has one.-----That screw has nothing to do withj shifting on a V-4 motor !!
Hennysemitara
mines is a 1984
jimmbo
Nowhere did the OP say what the engine was. Based on his original post it sounded like he took out the pivot screw near the skeg trying to drain the lube. Racerone is referring to a screw above the propshaft centerline.
Hennysemitara
Im talking about the philip screw starboard side of the lower unit next to the water intake screen.
???-----It has been stated that it is the screw that prevents the bearing from moving !!!----Not sure why more questions are asked on this ??
