photos 1970 60hp points conversion to timer base & sensor & a few other conversions .
durban
1970 60hp Evinrude points conversions to:timer base & sensor fitted using original crankshaft : Electroshift to Manual using the original intake manifold : From short-leg to 20inch leg using original exhaust & exhaust adapt-or : A wiring harness has been fitted & the solenoid was fitted in the original place where the factory has made the casting for it to be fitted , but due to the gear linkage interference , the solenoid was fitted on top of the exhaust box, this enables for another solenoid to be fitted & wired up as a safety should one fail out on the water :This model did not come out with a **** hole . After stripping a 70hp exhaust box i found that corrosion had eaten a big hole in the exhaust box , thus causing water to **** out through the exhaust & yet the **** hole was pissing water , so i had no idea i was loosing water , on this discovery , i decided to fit a **** hole on to this motor , & fitted another **** hole on the discharge , now I have 2 **** holes on this motor : 1 **** hole tells me the impeller is pumping water , & the other **** hole tells me water is circulating through the motor & not loosing it through the exhaust : A air box in front of carburetors was also fitted , all the parts were taken off a 1977 70hp . the points conversion is a tricky one as the timing had to be worked out , it works very well & goes even better, cheers
durban
1970 60hp pionts & condenser conversion to timer base & sensor assembly
more photos
durban
more photos
kodibass
Re: photos 1970 60hp points conversion to timer base & sensor & a few other conversio
looks like some very good work!
durban
thank you , & i have never heard of this being done , cheers
jbjennings
This is very neat, especially since I've worked on a '70 60hp, and absolutely hated the ignition system more than any other OMC I'd seen.
I don't fully understand the shifting conversion, however. Is it now hydromechanical instead of hydroelectric? I really haven't had any problems with the hydroelectric and actually find it to be a smooth working system, other than it being a huge PITA to change out a water pump impeller, and that it has all that wiring and switchery to go out-----on second thought, I can see why you changed it! :)
Anyway, nice job and I enjoyed the pics.
JBJ
durban
just as a matter of interest , i would like to know if iam the first person that has ever done this particular conversion , iam really courious to know ,as Ive never heard of it being done nor of a kit available to do this, especially from points to timer base & sensor conversion , iam referring to this model motor , any info would be appreciated , many thanks , cheers
tx1961whaler
I haven't seen anyone do this particular conversion on the ignition. There are a few that have used aftermarket CDI modules that still took the signal from the existing points.
durban
bricat 43 please put all your questions on this forum . by doing so we can share the conversion you want me to help you with the rest of the guys . & not on my private email k it will be my pleasure to help you , sweet m8t
durban
i am a bush African bush mechanic , u learn quick & fast in Africa when you go hunting & THE LAND ROVER breaks down in the bush in amongst the wild animals , while my m8t sits on the roof with the gun & i have got the engine out fixing it .
